another cam ?
Old Jan 9, 2007 | 01:23 AM
blockheadnic's Avatar
10 Second Club
Default another cam ?
I been looking again at texas speed cams and came across this one 228/228 .588/.588 the power range is from 1900 to 6800 will the stock 5.3 handle 6800 rpm. also whats the biggest i can go. its a big decsion so i want to get it right the first time, i also plan for N20 so i thought the bigger exhaust side would help for that. aslo plan on a torque converter
Old Jan 9, 2007 | 11:49 AM
negativeswitches's Avatar
you will need rodbolts to rev 6800
those stats on drivability and power are for a ls1 in a car not a heavy truck
n2o is very bias per cam around here do some research per vendor some people sell n2o cams proven to work better with the spray. all though they are full drag race cams you can see the pattern on which they operate and give you a good idea on what to be looking for in a daily driver cam
you'd prolly want about a 3k-3200 stall for that cam to get good out of the hole
-Erik
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
