AMW install w/RADIX question.
Old Sep 25, 2005 | 08:34 PM
paw's Avatar
paw
Default AMW install w/RADIX question.
Does the AMW catch can hook up the same way as in the instructions, or is it a different hookup with the RADIX?
Thanks
Old Sep 25, 2005 | 10:38 PM
CHarris's Avatar
I connected mine per the directions and it seems to be working properly. I drain it every couple of weeks and get a little oil out.
Old Sep 26, 2005 | 12:08 AM
04Denali's Avatar
going to install mine tomarrow. Just want to make sure I do it right. It will be my first mod that I do myself. You just connect it the the line that goes into the bottom of the radix air tube right before the TB?
Mark
Old Sep 26, 2005 | 01:48 PM
OCBC's Avatar
Anyone have a link to this catch can? (I know search, I am lazy right now)
Old Sep 26, 2005 | 02:07 PM
budhayes3's Avatar
PT's Slowest Truck
Gotta love honesty! Here ya go:
AMW Catch Can
In regards to the Radix question, I *thought* that I remembered reading that the catch can requires some sort of check valve for supercharged applications?? Might wanna contact AMW on that one
Old Sep 26, 2005 | 05:48 PM
OCBC's Avatar
Thank you kindly.
One question, does the "optional bracket" fit our trucks?
04Denali, I am curious as well.
Old Sep 26, 2005 | 06:02 PM
CHarris's Avatar
AMW Catch Can
I think the catch can is sucking off the valve cover (if I remember correctly) and the air is going back into the elbow in front of the TB, so, on a Radix, it does not see boost.
If you used the AMW with a paxton or some other centrifugal blower then you would probably have to use a check valve. Even still the hose out of a catch can should be able to be connected to the intake tract somewhere that is on the suction side vice the boost side.
Old Sep 26, 2005 | 07:26 PM
03sierraslt's Avatar
Does anyone else sell catch cans cheaper then 160.00! I might just have to make one.
Old Sep 26, 2005 | 08:27 PM
04Denali's Avatar
OBCB I got the optional bracket and it looks sweet on the front of the head. So if the extra 25.00 dollars is not an issue I would do it. Install went easy exept I was doing it on a hot engine. Also I will e-mail you the pictures of my exhaust tomarrow. Sorry it took so long. I had an issue with my e-fans (stopped working) that I had to figure out so I could drive my truck. Turns out I fried 2 relays some how. got it fixed though.
Mark
Old Sep 26, 2005 | 09:23 PM
OCBC's Avatar
So, did you hook it up with a bypass valve that has been talked about? OR is it cool on the radix without one? I really wish i had jumped on this thing awhile ago at $80.00
