alt/ps pump bracket
Old May 14, 2009 | 06:13 PM
lunchboxxx's Avatar
Default alt/ps pump bracket
deleting the power steering pump for clearence...the alternator bracket is also the ps bracket....is there a company tht sells a smaller bracket for jus the alternator??
thx
Old May 14, 2009 | 11:31 PM
Dark Halo's Avatar
not to sure about that but you may just be able to mod yours as needed
Old May 15, 2009 | 05:49 AM
lunchboxxx's Avatar
yea i was thinking about tht just wanted to check before hand....what would be ideal to cut the cast with??
Old May 15, 2009 | 09:37 AM
Dark Halo's Avatar
a sawzal with a metal blade would work just fine
Old May 15, 2009 | 10:19 AM
jasond26's Avatar
you can use the f-body alternator bracket, it will mount on the same side at the bottom. You will just have to tap the extra hole in the block.
Old May 15, 2009 | 03:38 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like that's where he needs the clearance though
Texas5.3_1251
Mar 5, 2016 08:10 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
InsaneDomestics
Sep 10, 2015 05:32 AM
InsaneDomestics
Sep 7, 2015 09:19 PM
slowswb
Sep 5, 2015 02:27 PM
