air intake questions
Old Apr 24, 2013 | 11:50 AM
nonnieselman's Avatar
yea newer ones with a 3 wire maf. Theres some of the older GM cars that have them also just cant rem which ones.
Old Apr 24, 2013 | 12:00 PM
lukn4trbl355's Avatar
i think im gonna go exploring this weekend lol, probably wouldnt be a bad thing to throw in even without the speed density tune, cant really see it hurting anything
Old Apr 24, 2013 | 01:14 PM
nope.. usually reacts faster than the stock one in the MAF.
IAT sensor wires are on one side of the MAF connector.. Tan and black.
Old Apr 24, 2013 | 03:13 PM
definitley gonna go snag one from the junk yard n hopefully find a grommet that works, and thanks man. while this turds parked i know what im gonna be doing lol
Old Apr 24, 2013 | 04:15 PM
TexasSteve's Avatar
Just use a IAT sensor from a Fbody or S10.. they are in every junkyard.
For the F-body IATs.....
The TPI IAT is nothing more than a Water Temp sensor. Not the most effective way of measuring.
Whereas the 3rd gen F-body V6 IAT uses an actual resistor in a screened housing. It can't get heat soaked by the pos that the TPIs use & is a common upgrade for the TPI to do when they relocate it out of the aluminum plenum forward into the plastic air duct.
Old Apr 24, 2013 | 04:20 PM
Dang thats nice to know!
The one i use looks alot like the one on the right.
Old Apr 24, 2013 | 07:23 PM
TexasSteve's Avatar
That is the correct one to use.
Old Apr 25, 2013 | 10:37 AM
atleast we got somebody that knows what they are talking about around here..
Old Apr 25, 2013 | 11:07 AM
glad to see all this good info, i was pretty pissed no f body ls's were in are boneyard but theres hundreads of the v6 ones there, next time i go ill for sure be grabbing one. one last dumb question after you depin the one from the stock maf how do you hook it up to the sensor itself? take a junkyard harness and just cut it? also where would the best location be on the intake pipe?
Old Apr 25, 2013 | 11:20 AM
TexasSteve's Avatar
The IATs that I posted above are from TPI & V6 82-92 F-bodies. I have no clue what the LS/98+V6 uses for IATS. The IAT is cheap enough at Autozone/NAPA/where ever so we just buy new ones, not used.
To put it in my air intake tubing, I bought the IAT then went over to Lowe's with it to find a nut that fit it. When I drilled the hole I made it just the size of the IAT shaft, not the threads themselves, so I was actually able the thread my IAT into the plastic itself. I can't recall if I put the nut on the inside as insurance to hold it or not but I know I was concerned that it could come loose & get sucked in through the throttle body.
