Aftercooler in new dyno numbers with pics!
With alot of help from some good friends the aftercooler is in. Will post some pics and dyno sheet soon.Yesterday the truck put down 511 rwhp :eek2: 421 tq at 11.5 boost.Can't wait to go to the track! The AF/C setup was designed by Meach13 , he also does the tuning and the pipe work on the engine, just to name a few things. Two other friends Jerry & Rusty helped an awful lot with numerous things. :cheers:
Re: Aftercooler in new dyno numbers
TIRBRNR is that a 5.3?What kind of numbers were you making without the intercooler?With 511rwhp you should be in the high 11s.
the truck is a 5.3 it was on pump gas not sure how much the aftercooler added but last time at the dyno made 425 we took off the fmu added some timing and added the aftercooler we were tired of having to run 100 octane with 11.5 psi to keep it from pinging so now we are on pump gas
http://www.meacham.pointclark.net/im...urtdynolow.jpg |
Very nice numbers. Are you running an air/air intercooler? Do you have any pictures of the setup?
:hail: :hail: :hail:
Now that is power! I cant wait to build my new motor! |
This is a liquid to air intercooler straight water and redline waterwetter NO ICE
Those are some good numbers congrats
how much timing are you running with that setup? What are your intake temps with the aftercooler? |
24 degrees and on the dyno they were about 95 degrees air outside was about 82
what intercooler i.e. Spearco? I will be doing a Spearco 2-230 by the end of summer :cool: How big is your heat exchanger? sorry for being a nuisance with the questions, I think what you guys did is great! any pics?
it is a spearco single core unit we are using a earls 12 x 12 oil cooler very very nice unit the pump is a jabsco pump pictures will be up tom
