Accelerated Cams?
Not to the best of my knowledge......it's going to sound like a sewing machine a little more than normal (mine will sound like this after the install) but I'm pretty certain that wear and stability will remain about the same as any other cam
Yes they will,but most cam manufacturers will tell you what valvetrain modifications are required to run their grind.Technically,all the performance cams on the market have accelarated lift when compaired to stock.If you follow the manufacturer's recommendations you shouldn't have problems.
Originally Posted by SportSide 5.3
The technology? You mean the idea of using fast ramped lobes? It's to pop the valve open quickly and enough to get the air in the chamber. (Or Out, for exhaust.
A need for more power. Slow lobes, spend all the time @ low lift levels where the head flows poorly.
Quick, steep ramps spend their time up top where the head flows more CFM. Also, they may provide less lobe around the base, where overlap is present. This is where you get the idea of fast lobes idle better.
Example.
Comp 3713 (x-e)
.006 - 273*
.050 - 220
.200 - 138
Comp 3720 (x-er)
.006 - 269
.050 - 220
.200 - 143
See where the small advertised duration on the faster ramped x-er is lesser. But check out .200 duration. More duration @ higher lift = more power.
Make sense? You see more cfm @ higher valve lift.
Example.
Comp 3713 (x-e)
.006 - 273*
.050 - 220
.200 - 138
Comp 3720 (x-er)
.006 - 269
.050 - 220
.200 - 143
If they are calling it an accelarated lift cam,they are only telling you that it has faster ramps that the cam it replaced.The only thing you can go by is what the manufacturer tells you,unless you have equipment to read and compare profiles,a cam with identical published specs from one manufacturer can behave totally different than same cam from another manufacturer.
