abs light ---problems??
Old Nov 13, 2004 | 11:27 AM
Kano's Avatar
Default abs light ---problems??
I was jacking up the side of my truck and
the jack slipped hitting the abs block I think
"its in front of the fuel filter" and bent it up to the
floor board.
from the looks of it, no lines kinked or broke so i bent
the bracket back down and tested it out
brakes worked fine except I had the abs light come on
and stay on
should I unplug the fuse for it so it dont do anything stupid
speaking of stupid where is the fuse? is it the 10 amp one
in the middle that says brake?
Old Nov 13, 2004 | 01:07 PM
BlownChevy's Avatar
blownerator
25 Year Member
You should check and make sure nothing broke when the bracket bent. I know Mack-o-da-year had and issue with driveability when he removed his ABS fuse.
Old Nov 13, 2004 | 01:33 PM
Kano's Avatar
nothing broke as far as I can tell
are there sensors in there?
Old Nov 13, 2004 | 01:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
I think so....maybe there is a wire that got pulled out? Check the plug??
Old Nov 13, 2004 | 08:34 PM
Yep and the electrical brain within is pretty expensive (it can be replaced seperetly though)
Have someone clear the code and hope for the best
No need to pull the fuse either, with the light being on the computer is recognizing that there is a problem within the system and it disables the ABS itself. You should have just normal brakes with no ABS
Old Nov 13, 2004 | 08:48 PM
Kano's Avatar
Ill try that
hope theres nothing wrong
brakework sucks
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
carid
Oct 1, 2015 09:22 AM
Blklgt
Sep 28, 2015 03:21 PM
Lthompson
Sep 21, 2015 07:06 PM
