aaaaannnnd, ANOTHER casualty from Comp 918 springs
Old Nov 23, 2011 | 05:32 PM
sand man's Avatar
damn thats ugly.. did the valve drop and damage teh piston?
i went with patriot dual golds.. no problems... that i know of at least
Old Nov 23, 2011 | 05:38 PM
SweetS10V8's Avatar
Is it me or does the spring look like it was installed upside-down??
Old Nov 23, 2011 | 05:43 PM
Phantom's Avatar
11 Second Club
holy ****! it damn sure does look like it!
Old Nov 23, 2011 | 06:52 PM
01silvy's Avatar
Yeah that spring looks upside down, but its kinda hard to tell with the pics.
Either way sorry about the motor.
Old Nov 23, 2011 | 09:20 PM
Coban's Avatar
PSSST. With a cam that small, just use these and save yourself future headaches....
Cheap too.
GM LS9 Valve Springs Matched Sets - Lingenfelter Performance
Old Nov 23, 2011 | 09:40 PM
sureshot's Avatar
It's hard to tell from the pics if it was installed upside down or not. I would think that it would've been installed correctly if all of the other ones were.
Cheap too.
I agree. With that small of a cam, you don't need anything more, and you wont have to worry about them breaking.
Old Nov 23, 2011 | 09:41 PM
SweetS10V8's Avatar
Cheap too.
PSST... dont recommend anymore parts to people.....
Those springs have a 1.190" coilbind height. Typical heads have a 1.77" installed height. 1.77-1.19= .580", the minimum distance to coil bind genrally accepted is .060". Your recommending he blindly drop in springs that will give him .030" to coilbind (1.77-.551-1.19= .029" distance to coilbind)
Old Nov 23, 2011 | 10:22 PM
sureshot's Avatar
Hmm.....I didn't know what the minimum accepted distance to coil bind was. Your math is correct, but doesn't the LS9 cam have more lift than what the OP is running? Also, Lingenfelter recommends these springs for cams with. 580" lift and under. They also mention that these springs have tighter coil bind height tolerance.
Old Nov 24, 2011 | 12:32 AM
jrmchevyman's Avatar
You are correct Lingenfelter does recommend these springs with .580 lift or below. I know that 1 or 2 guys on this forum are running the TR220 with LS9 springs just fine. I cannot remember the usernames.
*EDIT* I know that andrew383 runs LS9 springs on his comp 216/220 low lift cam.
Quoted from lingenfelter website: These springs are matched and sold in sets of 16 springs, checked by Lingenfelter for coil bind height to insure that they all have a maximum coil bind height of 1.190". This makes them compatible with the LPE GT2-3 camshaft and other camshafts in the .580" and under lift range with 1.800" installed height.
By sorting the springs LPE excludes LS9 springs that don’t meet the 1.190” specification. This makes them an excellent direct replacement for all stock LS2, LS6, or LS3 spring applications.
The LPE sorted LS9 springs are painted blue with a silver stripe for easy identification and actually have a tighter coil bind height tolerance than the LS2/LS6 springs that are no longer available.
The LS9 springs that don’t meet the 1.190” specification are also available from LPE at a lower cost, GM PN 12625033.
Old Nov 24, 2011 | 01:37 AM
SincalT/A's Avatar
Your missing the point that using ls9 springs in this case would be a gamble.I really dont think the op plans on cutting corners to save a lil dough at this point.That being said they may fit the bill too but,like all valve springs you should take the critical measurements installed within the intended application.I have seen a couple of ls style heads where the spring pocket height was out .015 from the another head.Still not enough distance to cover the clearance needed in this case.Valve spring specs are more a guide line for intial choice ,and should'nt be regarded as solid evidence they work in all listed applications.
