A4 - > M6 Swap COMPLETE!! NBS truck.
Old Nov 14, 2004 | 07:18 PM
  #21
1TRUESS's Avatar
Originally Posted by abbo7
Are you going to do a before and after dyno. One with the 4l60e and the other with the new 6-speed. It would be interesting to see how much hp you lost through the tranny of the 60e compared to the 6-speed.
I will be doing this!
And get some pics!
Old Nov 14, 2004 | 11:02 PM
  #22
retsell's Avatar
I will post some pics when I get the console section finished. I need to find a couple more parts and mod a couple things. I decided to swap in an 03 center console, which meant I needed to replace the glove box section, driver's under dash, and the console. The parts I found didn't match so I had the local paint supply store mix up some interior paint. I tore the console down into pieces and painted it all, got everything in and noticed the freakin paint doesn't match!! So, I get to tear it all down again. I have pewter interior (leather), which has a little brown in the grey. The paint they mixed looks light grey (close, but definately wrong) I even gave them a part to scan. It looks like the shifter is going to only take up the left side of the opening on the 03 console, so I will still be able to have a couple of cup holders on the right side. Once I get the console finished i will post pics. Any specific pictures other than the console you guys are looking for??
Also, I still think my belt is slipping. Still no tune from allen, so I won't say for sure, but the tensioner squeaks pretty bad for about 3 minutes on a cold start, and when I blip the throttle I can see it loosen up quite a bit. Does anyone have any idea what the tensioner for the radix comes off of so I can pick one up?
Old Nov 15, 2004 | 10:50 AM
  #23
TigerFan187's Avatar
Originally Posted by GoldenVelvet
I admire your testicular fortitude for attempting such a swap. Good job and post up some pics.
You are a God!
Old Nov 15, 2004 | 05:31 PM
  #24
6gear's Avatar
Ryan------ did you use a new flywheel or a used one? if yours was used did you resurface it? I have been running a spec II for about 16K miles with no problems of chatter or anything else. The 5 speed truck crossmember needs no mods. What gears are you running in the rear end? I orginaly had 3.42's then tried 4.10's and now have 4.56's and I wouldn't recommend anything less with the 6 speed and if a person was doing a lot of towing I would say 4.88.
Old Nov 15, 2004 | 06:53 PM
  #25
retsell's Avatar
It was a used flywheel and clutch the guy who sold it to me said it only had 1500 miles on it (I figured double it at 3k) but I inspected the clutch and flywheel and they looked good. I assumed that since it was already "broke in" I shouldn't resurface the flywheel with a used disk. I am using the stock 3.73, but I think I will try some 4.10. I may go ahead and get the 4.56 and I do a shitload of towing, but I would still like some decent gas mileage.
Old Nov 15, 2004 | 09:13 PM
  #26
6gear's Avatar
I could get 20 mpg if I drove decent with my 4.56's, I got a little over 19 on a trip but I drove 85-90 mph. I turn 2000 rpm's at 78 mph with a 29.7" tire. Don't even consider 4.10's if you are going to tow.
Old Nov 15, 2004 | 10:31 PM
  #27
retsell's Avatar
Thanks for the advise cause that's what I was going with. I really don't like the 3.73s, you think the 4.56 will be a good medium?
Old Nov 16, 2004 | 07:29 AM
  #28
6gear's Avatar
I think you won't regret the 4.56's, you have a heavier truck than I do but you are probably pulling more horses with the blower so that is probably a wash.
Old Feb 18, 2005 | 03:38 PM
  #29
Sport Side's Avatar
Hey retsell,
Any pics yet?
How about yourself 6gear?
Could someone scribble down a parts list?
5 speed Truck crossmember
T56
Thanks guys.
Old Feb 18, 2005 | 06:48 PM
  #30
retsell's Avatar
4.56 gears suck. I can tell you that much. Maybe with slicks, but on street tires, first and second are worthless.
