99 z28 cam on 99 5.3l
Old Nov 17, 2003 | 03:34 PM
Default 99 z28 cam on 99 5.3l
Will a 99 z28 cam work on a 99 5.3 gmc sierra? and if so do i need to change anything on the 5.3, like springs or anything else. Do i need to reprogram the pcm or can it stay the same.
Thanks
Old Nov 17, 2003 | 04:26 PM
silent1's Avatar
Thanks
Not worth the trouble:
https://ls1tech.com/forums/showthread.php?t=112450
Old Nov 17, 2003 | 04:28 PM
FILE's Avatar
David, here are the specs on both cams.
-1998-2000 LS1....198/209 .500/.500 119.5
Part #'s 12557812/1256965 (part # change mid 1998)
-2001-2002 LS1....196/207 .467/.479 116
LR4, LM7, LM4
-1999....191/190 .457/.466 115.5
Part # 12560966
-1999-2003....191/190 .457/.466 114
Part # 1256097 (Some 1999's had this cam)
As far as springs and pushrods, you should be fine with the stock springs since the max lift for these are .500.
lawhitediamante
Aug 12, 2015 12:14 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
lxcoupe
Jul 27, 2015 08:19 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
