918 spring life questions.
Old Oct 20, 2005 | 11:38 AM
marc_w's Avatar
Default 918 spring life questions.
Hi guys.
I've been running 918's for quite a while now. Maybe 30K miles. They've seen three different cams, for a relatively short time they were at a max of a little over .570" lift. Most of the time was .530". I'm back on the stock (LQ9) cam with ~1.82:1 rockers. Right around .513" and .500" at the valves.
When these springs start to reach the end of their life span... are they just going to lose tension which would comprimise high RPM valvetrain stablity -- or will they be in danger of failing at any time due to fatigue?
I've had some bad wrenching experiences lately and I'm gun-shy about going back in the motor for anything serious. If I can avoid swapping springs or just pulling my rockers to save some spring life, then I'm all for it.
Old Oct 20, 2005 | 12:29 PM
BigTex's Avatar
Honestly, I think those will last a LONG time. Personally I think they are one of the best single springs you can run. With the lift you are running now and the low rpm max shift (compared to a BIG cam), I'd bet they will last another 50K miles easily.
I bought my 918s used. The previous owner was running an XER cam with .580+ lift, upper 6000s shift points and put 5000-10000 miles on them. I've had them in for 2 years now, up to 6500 shifts and 15K miles. No issues at all.
Don't worry about them.
Old Oct 20, 2005 | 01:16 PM
marc_w's Avatar
Great, thanks for the reassurance Richard. That was basically my train of though too, but for some reason I've had a lot of mechanical paranoia lately.
Old Oct 20, 2005 | 01:24 PM
BigTex's Avatar
No problem. Just get over the paranoia and get back to enjoying the truck.
Old Oct 21, 2005 | 02:18 AM
Okie5.3's Avatar
i've only had mine in for 10k 5700 shifts and i don't give'em a second thought. could always pop a couple off and check the pressure at the installed height to ease the mind.
flatblack83
Jan 3, 2026 07:10 PM
jtphelps289
Sep 29, 2015 12:00 PM
sTNT971
Sep 11, 2015 02:38 AM
Forcefed81
Sep 8, 2015 10:02 PM
LT-1 SS
Sep 3, 2015 10:24 AM
