90mm LS2 Throttle body on 4.8
Old Oct 11, 2006 | 04:17 PM
regency's Avatar
Default 90mm LS2 Throttle body on 4.8
Would this be worth doing? Is it even possible or are the bore sizes of the manifolds different? With a tune what would be a good number to see gained from this if possible?
Old Oct 12, 2006 | 12:03 PM
SS_bnoon_SS's Avatar
Put that mod waaaaaay down on your list of things to do as most people here are making a LOT of power still using the stock throttle bodys. You would need a new intake manifold to make it work as the stock manifold opening is to small to try to port match to the 90.
If you want a more cost effective throttle body mod, do a search here and on ls1tech forums for porting the stock one. It's pretty easy to accomplish and does provide good gains for the buck on other platforms, though gains haven't been documented on trucks as far as I know.
jdb11386
Dec 3, 2015 09:34 PM
smokeshow
Aug 23, 2015 08:23 PM
Aboss
Aug 11, 2015 09:05 AM
Ammadien
Jul 22, 2015 08:50 PM
Gadgetized
Jul 7, 2015 04:40 PM
