'86 Silverado seeks LS1
I have an '86 Silverado and I have currently been thinking about putting in an LS1, a 4L60E (or seeing if my current trans. will work), don't know if driveshaft will have to be replaced, and also put in some lower gears. I know that it can be done. I haven't researched everything yet, but if somebody has done it, what should I expect as far as parts to get, and cost?
Its better to have a custom drive shaft because this was what happened to mine bent bed floor, bullet, and a hole in the nitto dr, after the 5.3 swap, TR224, no headers ,no stall and very little tuning
Here a vid of it, it a swap i would do again because there nothing like it even though I lost but not for long, full bolt on 06 with cam and stall.
http://s18.photobucket.com/albums/b1...itled_0001.flv
formerly 1BADC10 (12/14/2011)
Ahh... you should research as much as you can. I found it to be a surprise, but there has been a few LS-based swaps in '80s model box-bodies.
1BadC10's V8 Swap
Hope this gives you an idea of some of the work that would go into it. Mind you, engine placement will dictate driveshaft length, A/C compressor moounting, and exhaust placement. So, research as much as possible. Oh yeah... follow nightrunner's advice... spend the dinero to get a built 4L60E or 4L80E. 60s do not last. (see my sig)
1BadC10's V8 Swap
Banned
1 Post
one of me and rons friends also put an ls1 in a 2001 s-10 and it is a bad a$$ fit
1BADC10 - did a great job with his truck and he has be through alot putting it all together
