8.1header difference?
Old Oct 23, 2007 | 06:21 AM
HemiHunter's Avatar
Default 8.1header difference?
I've been looking at some different headers for my 04 2500HD (8.1 Allison) and found a set for a 01-02 8.1 W/O air for a really good price.What is the difference in the exhaust from 01-02 to 03-04? Can they be used at all?
Thanks for any info
Old Oct 24, 2007 | 01:10 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Does your '04 have EGR? I believe the 01-02 trucks had a EGR port on the passenger side manifold. I think they did away with EGR in '03 or '04, so all you'd need to do is just block off the EGR port on the '01 header. I bet they will work just fine.
Old Oct 24, 2007 | 02:48 PM
HemiHunter's Avatar
No EGR on my 04. The 01-02 models could be either way. but headers for 01-02 w/o egr is still a different part number???????
Old Oct 24, 2007 | 10:03 PM
Manic Mechanic's Avatar
Are you talking long tube or short? If it's a shorty designed to replace factory manifolds it will fit. If it's a long tube it may require some slight pipe rerouting. It's all very close, there were no major redesigns. I picked up some long tube Stainless Works and the drivers side wraps under the bell housing towards the exhaust system. There's probably some slightly different alignment, pipe sizes and locations are the same.
Vernon
twake_410
Apr 14, 2016 09:58 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
