8.1 Allison Auto 4x4
Old Jan 5, 2004 | 11:45 AM
Mater's Avatar
Default 8.1 Allison Auto 4x4
DUALLY CREW CAB!!What mods can i do to make it bad ***!!
is the rad to big for e-fans??tuning,exchaust,headers,air intake,etc!!! any ideas guys?? thanks!!
Old Jan 5, 2004 | 04:11 PM
tbyrne's Avatar
This would make it bad *** -
and the Flex-a-lite 295 fans can be used with the big radiator -
The install was a little cleaner when I was done
Besides these mods you can also go with aftermarket headers, intakes, programming, catbacks, cams ect... There are quite a few options available. We have a seperate section of the 8.1 trucks on our website.
Hope thlps helps,
Tom
2002 8.1 Silverado HD - Comp Cam, TOGs headers, Volant induction, Direct Hits ignition, 8" lift 18" wheels/tires + more
2002 8.1 Suburban -Intercooled Whipple supercharger, TOGs headers, Volant induction, 22" wheels/tires + more - 407hp/558 ft-lb torque at the rear wheels.
www.tbyrnemotorsports.com
Old Jan 5, 2004 | 04:25 PM
Mater's Avatar
thanks tom!!
Old Jan 6, 2004 | 11:39 AM
Mater's Avatar
anyone else??
Old Jan 6, 2004 | 02:30 PM
Texas Terminator's Avatar
11 Second Club
you have all the right ideas, just do it! computer tuning will do more for it for your dollar than anything else. the flex-a-lite 282 fans tbyrne shows would be a direct fit for you if it has the 34" radiator like the 6.0's.
Old Jan 17, 2004 | 12:52 AM
Raylar's Avatar
Spend your first hard earned money on good 4 into 1 equal length headers and a good cat back system. After that a good cam and computer reprogram will give you the best bang for your buck! The engines a fuel burning air pump, you can try to add air on the front end, but if you don't get it out smoothly on the back side you won't find your Bad *** power!
Old Jan 17, 2004 | 10:02 AM
christ, i couldnt IMAGINE the gas milage you would get with a 8.1L motor AND a positive displacement blower.
calsdad
Jun 14, 2023 11:07 PM
dsbodley
Nov 14, 2015 09:46 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
dantheman1540
14
Sep 28, 2015 09:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
