703 RWHP 4x4 6.0L
Old 12-20-2004, 12:50 PM
10 Second Club
04BlackGmc's Avatar
Wow! Thats alottta power.
Old 12-20-2004, 12:52 PM
GMC SKI's Avatar
what Head gaskets are you using and what are the Specs on the cam
Also what is the compression on the motor ?
Old 12-20-2004, 01:03 PM
Former Vendor
Speed Engineering's Avatar
Yes it is that one. And we are running copper/o-ringed head gaskets with around 8.1 Compression. Comp cam 220/224 .564/.567 115 LSA. Believe it or not he wanted a cam he could pass smog with here in CA.
Old 12-20-2004, 03:33 PM
2toneblown's Avatar
wow ver impressive. Cant wait to see what my 408 with the F1R will do with about 3 times the amount of boost and good heads and ALOT bigger cam
Old 12-20-2004, 04:17 PM
2000 SILVERADO's Avatar
That's a lot of HP. How much did all of this cost you?
Old 12-20-2004, 04:45 PM
Former Vendor
He probably has a good 15,000.00 including Fuel system, Charger, Motor, & Tranny. We have another one in the process of being built. It includes a 383 with the same charger. We plain on running around 15lb. of boost and a small shot. The cool thing is that it is in a single cab chevy 2wd. We are shooting for 800-900 Hp. The main problem we are going to have is trying to make it hook. We are going to build a custom four link for the truck.
Sean
Old 12-20-2004, 06:15 PM
Flyer's Avatar
Do ya'll have 4 link kits available?
Old 12-20-2004, 06:25 PM
Former Vendor
We are actually comming out with a lot of things for the truck. LS6 intake swap kits. Longtube headers with a bolt up off road Y. Rear end suspension components. Fuel systems specifically for the trucks with lots of HP. Lots of stuff you guys always do, just as kits.
Sean
single digit dreamer
parish8's Avatar
wow! from what i am seeing with my diferent set up's and dyno trips these numbers are just hard to believe. could your boost gauge be messed up?
got a few more questions if you dont mind.
dynojet?
4l60e?
with the big tires?
thru a tcase?
locked converter?
what gear?
what rpm for peek hp?
those would be good numbers fro 18psi let alone 8psi. i want to know what your secret is.
Old 12-20-2004, 06:27 PM
parish8's Avatar
Sean
sounds great! we need more stuff
Quick Reply: 703 RWHP 4x4 6.0L
