6 liter transplant fuel pump
I am putting a 2000 6.0 liter in a rock truck/buggy and need to know what fuel pump this thing is going to want to make it run. Inline is of course the major spec. The engine will remain stock as it puts out enough for the application. Thanks for the help,
Kelly
Kelly
Banned
what did the truck come with.if it came with a v8 you should not have to replace the pump.you may have problems some were else. try to remove o2 sensors to if cats or cloged(front ones of course)
Na, the truck is an S-10 cab hollowed out on a full tube frame.
it has a fuel cell in the back. I need a pump that will put out the pressures and last. It will be on a toggle or on the ignition, still to be decided. I know there is one out there, just need a part number.
thanks,
Kelly
BTW, if this is in the wrong forum, sorry. Posted it here because the engine is out of a truck that belongs in this forum.
thanks,
Kelly
Well, I dont know for sure, but most guys around here seem to be operating at the 50 psi @ idle and 60 @ WOT. So you could use those for a decent start at what you need to look at for an aftermarket pump.
Just tryin to help.....
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
