6.2 Info
Nope.
Everything is completely different. The displacement is the same and that's basically it. You could never make the motor run with a E38 controller nor could you make the newer computer work with your wiring harness and other BCM/TCM etc etc etc.
Plus 14+ are direct injection engines with specific fuel systems and electronic parts.
In short only a 07-13 block will swap in and work the way you want it.
