Is this 6.2 block salvageable?
Old Dec 19, 2019 | 08:14 PM
LOWnEASY's Avatar
Default Is this 6.2 block salvageable?
Acquired this block from a buddy for helping him do some work, I'm just curious if its salvageable or not.
one of the valve seats drop and destroyed the piston and put a hole in the sleeve/block mabey a little larger than a quarter and goes through to the water jacket.
(hole is twords the inside of the block)
Old Dec 19, 2019 | 11:16 PM
arthursc2's Avatar
MID sleeves and it'll be good to go
Old Dec 20, 2019 | 08:15 AM
LOWnEASY's Avatar
That's big money though
Old Dec 20, 2019 | 09:16 AM
arthursc2's Avatar
Then scrap it. There's no viable repair for a stock sleeve damaged like that
Old Dec 21, 2019 | 12:52 AM
stroker87's Avatar
i bought a complete 6.2 engine that was apart when i had every thing looked over a couple bores had some scars that needed more boring then i was ok with for what i was looking to do, i looked in to getting it sleeved when i found out the cost i bought a new GM block
Old Dec 22, 2019 | 12:55 AM
1FastBrick's Avatar
Custm2500's Rude Friend
You can have that 1 hole sleeved. It's about $100 for the sleeve. They machine the bore out and leave a little step toward the bottom of the cylinder. They do an interference fit and use an adhesive to bond the sleeve to the block. They usually shrink the sleeve with dry ice or liquid nitrogen and drop it in. When it normalizes it expands.
Talk with your local machinist and see if its cost effective for you. It might run about $300 in labor to sleeve and bore the hole to save the block.
Old Dec 22, 2019 | 09:30 AM
arthursc2's Avatar
That won't fix the hole in the aluminum tho. That just replaces the liner
Old Dec 22, 2019 | 05:22 PM
swathdiver's Avatar
5 Year Member
Melling makes replacement sleeves but that might be a boat anchor. The machine shop will know.
Old Dec 23, 2019 | 01:19 AM
1FastBrick's Avatar
It can be repaired. The question is whether or not its cost effective to do so
Old Dec 24, 2019 | 12:20 PM
00pooterSS's Avatar
You're a good friend to have if you work for trash lol
