6.0 swap problems
Old Aug 28, 2013 | 09:45 PM
gmc123's Avatar
Default 6.0 swap problems
I swapped my 5.3 for a cammed 6.0 a couple months back and finally it got to where It was running pretty good but starting hard. I noticed I had a cel for a cam positioning sensor so I put the cam positioning sensor from my 5.3 to see what would happen. Now the truck starts fine but says it is misfiring on all cylinders. No idea what is going on here? Anyone have any ideas?
Old Aug 28, 2013 | 10:33 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Did you ever do a crank relearn after swapping the sensors???
Did you Check Fuel Pressure???
Old Aug 31, 2013 | 12:46 AM
1FastBrick's Avatar
To better understand the Crank relearn and why it should be done after replacing sensors or PCM's read this document. CKP Variation Learn
Old Sep 2, 2013 | 08:56 PM
gmc123's Avatar
Thanks for the help, The after the relearn it runs and starts much better! Finally starting to run like I want.
Old Sep 3, 2013 | 12:53 AM
1FastBrick's Avatar
Glad to hear!
ferrellrooster
Mar 6, 2025 03:22 PM
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
