6.0 swap done with problems!!! help
Old Feb 12, 2008 | 05:18 PM
  #41
dlt76028's Avatar
took the rockers off and #1 has 0 compression so i have to pull the engine again. and what makes me mader then hell is i think the people i bought it from knew about the engine!
Old Feb 12, 2008 | 08:16 PM
  #42
hirdlej's Avatar
wait wait wait, before pulling the entire motor, yank the head off that side of the motor. Remove the valves from that particular combustion chamber and put some valve seat dye onto the face of the valve and gently rotate the valve in its seat. Remove the valve after a full rotation and look at the dye on the seat of the valve. Make sure the dye is completely spread around evenly on the valve seats. If not, you got a bad head job from someone.
Old Feb 12, 2008 | 08:35 PM
  #43
dlt76028's Avatar
I think i saw what that dye your talking about around the valves when i picked them up it was pink or red? and it was all the way around. plus its doing the same thing before and after the valve job...
Old Feb 12, 2008 | 09:06 PM
  #44
6.0 Hoe's Avatar
Your rings could be so trashed that the oil in the cylinder trick won't work. Swap the heads from side to side and see if the problem follows the head or stays with that side of the engine (pistons/rings). Sounds like you need a simple rering job. It sucks and is a big pain in the *** since you already finished the swap but this is just one of the reasons you never take someone's word on engine condition. Also, before long term storage you should fog the engine.
Don't worry, it will be worth it when you get the short block back to 100%.
BPD
Old Feb 12, 2008 | 09:22 PM
  #45
dlt76028's Avatar
BPD
Thats the only thing thats keeping me going... thanks
Old Feb 14, 2008 | 06:52 PM
  #46
dlt76028's Avatar
Engines back out. it only took 3.5 hours to get it out snese i've tore it down so much. its at the machine shop but their busy so who knows how long? i hope its just rings...
ferrellrooster
Mar 6, 2025 03:22 PM
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
