6.0 Number decoding?
Old Feb 18, 2005 | 04:53 PM
rob3379's Avatar
Default 6.0 Number decoding?
I just purchased a 6.0 and need to decode numbers and find out what are the specs of the motor.
Thanks,
Rob
Old Feb 18, 2005 | 06:31 PM
04BlackSilverado's Avatar
What are the #'s?
I may be able to find out for ya.
Old Feb 18, 2005 | 07:13 PM
rob3379's Avatar
The heads have 317 stamped on them. The block has S13, GM-SMCO, H05, and G05 stamped on it.
Could someone please give me the specs on this engine?
Thanks,
Rob
Old Feb 18, 2005 | 07:45 PM
Sorry to jump in like this but, I have the same question about infor on an engine. The engine is a 6.0, HEADS ARE CASTING NUMBER 317 - BLOCK IS CASTING NUMBER 12561364. Any help would be greatly appreciated....
Old Feb 18, 2005 | 07:54 PM
99Silver6.0's Avatar
You guys are cool on the heads. The 317's are the ones you want. Id compare block numbers with you but im nowhere near my motor. But a truck 6.0 block is a 6.0 block. What makes the difference is whats inside I.E. pistons and rods. You can yank the plugs, grab the crank pulley and spin it over till you can clearly spy a piston crown through a plug hole. A dished piston denotes an LQ4 and a flat top tells you its an LQ9.
Old Feb 18, 2005 | 09:57 PM
rob3379's Avatar
Does anyone know were I can find the numbers on the motor.
Thanks,
Rob
Old Feb 19, 2005 | 04:24 AM
rob3379's Avatar
Anyone!!
Old Feb 19, 2005 | 05:35 AM
CHAGO's Avatar
try using this:
Old Feb 19, 2005 | 02:26 PM
rob3379's Avatar
Ok does the LQ9 and LQ4 have the same rotating assembly.
Old Feb 19, 2005 | 02:47 PM
rob3379's Avatar
Ok I found the numbers 12551364 on the block. It looks as if it has a light dish in the piston but very slight. Is the and LQ4?
