6.0 lq4?
Im thinking of upgrading my 5.3 to A 6.0.The truck is my daily driver and I also pull A trailer.I found A 6.0 lq4 with low miles .Looking for suggesttions on A good cam choice and any other low buget upgrades.Also, Is the stock y pipe /Cats ok to use? Truck is A 05 ec sb with 3:42 gears
You will love the 6L... i dont know much about the cam aspect, but i figure a 208ish cam should do you just right..
We put a 2004 LQ4 with a LS6 cam/springs in my buddys 07 classic ECSB 3.73s. it pulls hard.
But for what your lookin for to tow, a low end cam would be alot better..
Welcome to PT.net
The 6.0L swap is a well documented upgrade and for towing a great choice. There are 2 5.3L engines available in the 2005 ECSB, which do you have?
As far as cams go, it's a personal choice but for towing you want something with less duration than most might recommend for the track.
Upgrading those gears to 4.10's will help immensely as well!
Welcome to PT.net
I have the aluminum block 5.3.
fugger!!
