6.0 carbed
Old Aug 16, 2011 | 11:32 AM
04blackvho's Avatar
Default 6.0 carbed
ok so if i guy a used 6.0 what do i need to make it run with a carb can i use the th 350 trans
Old Aug 16, 2011 | 07:09 PM
06murder's Avatar
yeah u can use the th350..did you get a spacer with it an flexplate if you got them both ur good to go,just bolt it together
Old Aug 17, 2011 | 08:43 AM
baSICK5.0's Avatar
Summit sells a kit with an intake and ignition moduel to run carb
Old Aug 17, 2011 | 11:04 AM
00buckshot's Avatar
Mods, we need a CARB section please!!! These questions are getting common. but to make the trans work all you need is a flexplate spacer form GM, someone else may have it too, an 80e flexplate and you can bolt the trans right on up and be done. Now on the motor side, get the MSD 6LS box and it comes with a nice harness that plugs right on into all the factory sensors on the block, you will have to give it a ground source a batterty source and an ignition source. Than use your choice of intake and carb and get fuel to it and let her rip........
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
