6.0 Build
Old Mar 24, 2005 | 10:58 AM
Dub Silverado's Avatar
Default 6.0 Build
I want to do it a 6.0 build and need to know what to look for when looking for a motor. What codes do i need, etc. I just started to look so i need some help. Thanks in advance
Old Mar 24, 2005 | 11:09 AM
gonzo 6.2's Avatar
Start with the search button,that will get you educated so questions wont be so general.
Old Mar 24, 2005 | 11:46 AM
01Blackerado's Avatar
One thing i must say is if you decide to buy a bare block make sure that none of the mains have spun on the block!! Also check for pitting in the cylindar walls
Old Mar 24, 2005 | 12:27 PM
ACDenali's Avatar
I believe the LQ4 which is in the silverado ss's and escalades is the highest hp 6.0. I am assuming the blocks are the same on all of them. The heads and cam might be slightly different, not for certian though. Good luck, what kind of numbers are you looking to get, and will it be N/A or forced induction?
Old Mar 24, 2005 | 12:31 PM
KLUG'S SS's Avatar
FormerVendor
SS's and Escalades have the LQ9.
gonzo 6.2's Avatar
Denali/all 6.0s = LQ4
SS/Escalade = LQ9
Accurate info is availible using the search
Old Mar 24, 2005 | 12:33 PM
Scream's Avatar
MOOBIES Moderator
The SSS and Esky's use the LQ9.
Old Mar 24, 2005 | 12:34 PM
hit em with the search
Old Mar 24, 2005 | 12:46 PM
There is so much info by doing a search that it gets overwhelming. Which block is better the LQ4 or LQ9? I dont know if im gonna do NOS, Turbo, or supercharger. This is my daily driver for now until I finish school, so I need something that will be reliable and streetable. I have been considering doing a custom turbo kit, or maybe a NOS motor. Im kinda looking around for what seems to work best, and what other people have had good success with.
Old Mar 24, 2005 | 12:57 PM
Hey do me a favor dont say NOS, say o2 or N2o or nitrous unless you decide to get Nitrous Oxide Systems kit. Sorry im just messin with you... ok enough of the games. The LQ4 and 9 differ only in slight piston dish, heads and i beleive cam but im not sure on the cam part!! The CR is higher in the LQ9 and the heads flow a little more, If you plan on doing this build completly custom then I'd suggest going with the Lq4 and make it into whatever you want...Really i suggest getting a bare 6.0 block and going from there that way you have everything inside and out of what you want it to be!!
