5.7 in a truck with a Radix???
I thought about it but decided on a stroked 6.0 block.The 5.7 has a lot going for it an increase in displacement plus freer breathing cam and heads along with a 100lb weight loss.The only down side might be the higher compression you probably need to run 9lb of boost or less.You'll also need a really strong transmission,a 4L80E is probably the way to go or maybe a 6 speed manual.
therock
Jul 25, 2015 09:23 AM
