5.7 heads on 4.8
Old Nov 3, 2006 | 07:31 PM
1998TA__1991RS's Avatar
Default 5.7 heads on 4.8
i just came across a set of 241 casting ls1 heads for free, all the intake valves were bent. if i got the heads shaved down a little could make more power than the 4.8 heads, also would they bolt up?? and what size valves should i go with
Old Nov 3, 2006 | 10:07 PM
v8
17,16,15,14,13,12,11 Drvr
they will bolt up, you would have to shave them .050 to keep your compression the same, problem is the 3.77 bore compared to the 3.90 bore the 5.7 has, the valves will be very close to the wall.
Old Nov 4, 2006 | 01:16 AM
Mangled03gmc's Avatar
Baltimore Whore
You can run them but it will drop the comp alot, might work good if you intend to put a turbo or blower on, othwise you will need them milled like stated above
Old Nov 4, 2006 | 08:03 AM
would i run into any problems with the valves hitting the wall?? and if i were to go witha radix or a maggie what would it drop my compression to?? are these heads much better than the stock '05 yukon heads?
Old Nov 4, 2006 | 08:15 PM
ttt....
Old Nov 4, 2006 | 10:43 PM
tdrumm's Avatar
Stock 241 heads don't flow any better than stock 862 or 706 5.3 heads.
Old Nov 5, 2006 | 12:26 PM
are the 862 and 206 5.3 heads also used on 4.8's?
Old Nov 5, 2006 | 12:42 PM
tdrumm's Avatar
Yes they are.
Old Nov 5, 2006 | 07:17 PM
ok cool,i may try to trade for a set of 5.3 or 4.8 heads to work over
Dan Neumann
11
Aug 7, 2022 09:06 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
4B11T
Jul 13, 2015 03:48 PM
