5.3L Tahoe hard to crank
#24
#27
Need to put a fuel gage on the rail and test it. Pull the vacuum line and it should jump up 8-10 psi.
If it does not, it might not be working correctly.
Have you cleaned the throttle body and idle air control valve?
#29
I did clean the TB but where is the IACV?
#30
If you have a DBW throttle body, you have no IACV. If you have a DBC, it's the small gold round thing on the upper right side. The holes in front of the blade are where the IACV draws from.
