5.3 Yukon DOD delete and ls2 cam
Old Jan 30, 2016 | 11:53 PM
6cummins's Avatar
Default 5.3 Yukon DOD delete and ls2 cam
What's up everybody. Got a low mileage 09 Yukon that spun a lifter and ate up a lobe. Decided it was time to do a DOD delete etc. Going to install a stock LS2 cam out of my buddies 06 Trailblazer SS along with LS6 springs and LS7 lifters. I know I need a 3 bolt cam gear, Is part # 12586481 the correct gear I need? I know the GEN IV 5.3s have a little higher compression. Would I benefit any milling the heads some to get the CR up a little more? Truck is a DD and not looking to get crazy, just a little extra then your average stock 5.3
Old Jan 30, 2016 | 11:57 PM
FFDP's Avatar
I'd leave it alone.
The heads are already great flowing, just make the tune good.
Old Jan 31, 2016 | 12:55 AM
Wolftrk99's Avatar
Are the ls6 springs enough for the ls2 cam??
Old Jan 31, 2016 | 01:33 AM
6cummins's Avatar
Was under the impression that ls6 springs are good for .550-.570 from what I have read.
Old Jan 31, 2016 | 08:13 AM
Wolftrk99's Avatar
Isnt the ls2 cam right at .550??? Putting it right at the threshold then?
Old Jan 31, 2016 | 09:34 AM
6cummins's Avatar
.525 is the ls2 cam..
Old Jan 31, 2016 | 02:24 PM
Wolftrk99's Avatar
Ok ive been looking at so many cams lately i think i confused myself....lol
Old Feb 1, 2016 | 07:41 AM
6cummins's Avatar
Where's a good site to find torque specs? Looking for specs on "heads, harmonic balancer, timing cover, cam gear, exhaust manifold, intake manifold and valve covers".
Old Feb 1, 2016 | 08:06 AM
Tootall's Avatar
torque specs, LS1howto.com
Yes, LS6 springs and stock push rods are fine.
If you wiped out a cam due to the DOD lifters, plan on saving for an engine swap.
Old Feb 1, 2016 | 09:43 AM
6cummins's Avatar
No it was a regular lifter on #2.. caught it soon as it happened. Damage was very minimal.
