5.3 vs 243 Heads...Confusion
#32
Originally Posted by slowprocess
A more budget friendly alternative might be to go with a set of milled 6.0L heads. They've worked good on my TR224 6.0L setup. Just food for thought
#36
Originally Posted by tdrumm
I do not know exactly how much milled = how many cc's are removed, but I can tell you that the porting that WCCH did to my 5.3 heads increased the chamber size to 65cc, same as a stock 243. Then milling them down .045 brought the chambers to 58.8cc. .045 was the max that Richard recommended milling them to avoid intake fitment problems, although a few here have milled them slightly more. I haven't heard of anyone ever shaving one of the stock intakes to help it fit with milled heads. Keep in mind that milling heads also reduces piston to valve clearance, although a .045 mill with even a .045 head gasket should be fine with a TR220.
Unported LS6 heads milled down to 58.8cc chambers with a 3.910 bore x .045 thick gasket on a stock 5.3 shortblock will net you ~10.0:1 compression.
#39
Originally Posted by pbraxton
how much milling is req'd to bring the 243 head chambers to 58.8cc.
#40
I'd put an educated guess that it would be around .045 like mine, but I bet that Richard at WCCH could confirm that. might want to try shooting him a pm.
