5.3 tick..... louder than normal ticking..... another problem
Old Oct 10, 2007 | 07:27 AM
litreddevil's Avatar
Banned
Hey guys....
Got another problem to share with yall...
Ok the ole 5.3 has always had the tick on start up and when warmed up..
Nothing major, now its really Ticking at anything above 1500 rpms.. with no load or load..
It pulls timing like crazy sometimes... but in boost its a hit and a miss...
This just started.. ive tried changing the VE Tables and timing... nothing helped.. ITs runnin rich also....
I ran it in Closed Loop and got the fuel straighted out in Vaccum but lean in boost.. but the Tick/Knock is still there
I pulled the Passenger Side Valve cover since the noise was coming from what it sounded like good ole Number 7..
Goin to do a leak down test on all the cyls and compression test....
165k miles and it looked new under there.. everything was tight.. Springs and rockers.
Goin to put the torque wrench on everything when i get home..
Might pull the pan and see if i have any suprises in there..
Does anybody have any ideas?
Suggests?
Advice?
I was thinkin about a LQ4 and ARP bolt it and start over...
yea i hate to tell you but pass, side in not where #7.hahahaha
i got my 370 just wanting for some boost.
Old Oct 10, 2007 | 09:30 AM
shandy294's Avatar
It's ticking and not piston slap? Let us know what your leakdown and other tests reveal/don't reveal.
Old Oct 10, 2007 | 10:19 AM
Tootall's Avatar
How long does it take you guys to do a Engine R&R???
started Friday afternoon, stopped at 10:30, finished Saturday evening . . . .
Old Oct 10, 2007 | 07:51 PM
nonnieselman's Avatar
Driver side valve cover
Whats your price....
Old Oct 11, 2007 | 08:46 PM
Got the fuel back right...
But that dang ticking noise is horrible...
Anything above 1500 rpms and its there...
Below 1500 and i cant hear it...
It changes with RPM.. not load...
In P or N i can slowly rev it up and she starts singing at 1500+
With the converter locked in 3rd and doin bout 28mph i can get on it and it seem like right at 1500 it starts the noise...
What yall think?
Should have the Compression tester tomorrow...
Goin to do all 8
Whats considered Good Compression??
Old Oct 11, 2007 | 08:49 PM
Just found the trusty ole book...
It says for V-8s Minimum Cylinder Compression Pressure 100PSI
Maximum variation between Cylinders 25% from the highest reading...
Old Oct 12, 2007 | 12:28 AM
Spoolin's Avatar
GFYS and STFU
That sounds like Valve train if it's dependant on RPM...valve float?
Old Oct 12, 2007 | 08:31 AM
Would the valves float at 1500rpms??
I took the DS VC off and tried to move the springs and rockers....... everything was tight..
Ill pull the Passenger side VC when i get off work and see whats under there..
Old Oct 12, 2007 | 09:23 AM
ranwalk's Avatar
May be a lifter
Old Oct 12, 2007 | 09:26 AM
Tootall's Avatar
try getting a new oil pump with the red o-ring and see what happens then, but it does sound like a lifter. Pull the VC and run the engine, see which rocker isn't spitting. . . . lay some towels out first.
