5.3 LM7 head gasket questions
Old Jun 24, 2018 | 05:00 PM
js17hilton's Avatar
Default 5.3 LM7 head gasket questions
Hi,
Im trying to source some head gaskets for my 2006 LM7 5.3. Im looking for a slightly thinner set. I don't want to put the factory .051 thickness back in. I want to just slightly increase compression without milling the heads.
Ive found several .040 gaskets from cometic, but I cannot find weather or not it will fit my engine. Can anyone give me some advise?
This is that I'm looking at right now. https://www.briantooleyracing.com/co...d-gaskets.html
I would think I would just pick 3.9 bore, and .04 thickness. Will this work for me?
Thanks
josh
Old Jun 24, 2018 | 07:23 PM
trxmxzx's Avatar
13 Second Truck Club
Originally Posted by js17hilton
Hi,
Thanks
josh
im don’t think your going to gain with with what your looking at.... those are 5.7 size
Old Jun 25, 2018 | 08:46 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Hi,
Thanks
josh
Yes, this will work. The OEM gaskets are similar in bore size.
Old Jun 30, 2018 | 04:28 PM
js17hilton's Avatar
Thanks 1fastbrick.
does any one know if there would be any problem with running that thin of a head gasket? m y pistons are about .005" out of the hole at tdc.
Old Jun 30, 2018 | 06:21 PM
1FastBrick's Avatar
Hard to answer 100% yes or no. Likely it will work with out issue. You should measure the piston rock at the top and bottom just to see how much you have.
It will tighten the quench area.
KyleM325
Nov 28, 2016 11:10 AM
hollywood_35
Nov 22, 2014 10:23 PM
Relentless07Silv
May 5, 2014 03:40 PM
Gadgetized
Jul 5, 2012 05:08 PM
shakinlm7
Jan 19, 2011 01:28 PM
