5.3 Flat Top Pistons-
Originally Posted by BigTex
You can take a 6L block and add a 4.8 crank to it. Thats a 4" bore with a 3.267" stroke (101.6mm x 83mm). That would give you 328 cubic inches. You'd benefit from the higher revving short stroke and power from the larger bore. Add a set of diamond pistons and LS6 heads.
Hmmm...this reminds me of the old days when we took 327 blocks and put 283 cranks in them with the L79 cam and built 302s.
So, anybody got any of these pieces cause all I got is the heads and a 5.3.
I'm sure you can find a 4.8 crank pretty easily for pretty cheap. Used 6L bare blocks can be had for a couple hundred. That would make a nice "327", but I'd sure hate to give up that extra 40 cubic inches.
I got it! Take a standard 6L block, bore out to 4.020 then add an Eagle 3.9" stroker crank. You'd get exactly 396 cubic inches and would make a ton more torque and power. Think 450 rwhp and tq compared to 350 of the 327. That sounds perfect for a classic nova.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Boy, the possibilities are endless! OldNovaGuy, you can now have your HO 396 "big" block cubes instead of the 327 small block.
OK, now are you more or less confused?!? The advice is solid and plentiful.
Do you happen to know if the parts will actually interchange? Will the crank fit? Use the 4.8 rods (nice and long)? Do you happen to know what the combustion chamber volumes are of the stock 4.8 & 5.3 heads? Can you direct me to some of this kind of fundamental info regarding mixing these parts? Lots of questions, I know, but any help is greatly appreciated. Thanks!!
Andy
makin' a spinner
Originally Posted by Andy1
Big Tex,
Andy
Andy
Bigger J,
The only thing is your intake wont support that high of an rpm. Also, you'd have a very narrow powerband. You'd probably wanna think about one of those carb setups with the single/dual planes to spin the motor past 7k.
It would probably be a total track setup because you'd need a high stall converter to feed you into the desired power band.
Originally Posted by SportSide 5.3
Bigger J,
Intake/Exhaust flow aside do you think the LR4 rotating assembly can handle 7-8k at modest torque (~400lb-ft)?
Bigger J,
BiggerJ, I'd advise you check for any required balancing of the rotating assembly when mixing parts. Any motor builders out there?
Andy
Andy
Balancing
Originally Posted by BiggerJ
Kinda neglected that part. Does anyone know the difference in weight between the 4.8 vs 5.7 pistons? Since this is the only difference in the rotating assembly, would this difference in weight matter?(my guess is yes) Maybe custom pistons to match the 4.8's weight would be the easiest solution(I'd rather stay cheap). How expensive is it to get a stock crank rebalanced?
Andy
bbowerman
07-26-2015 10:57 PM
