5.3 Conversion started today!
Old Apr 19, 2007 | 07:40 PM
JeevesRules's Avatar
Default 5.3 Conversion started today!
i posted on the conversion ls1 side because of the amount of traffic they get over there but i wanted to show you guys what was going.
https://ls1tech.com/forums/showthrea...38#post6901638
let me know what you think
thanks again
Old Apr 20, 2007 | 02:32 PM
BigTex's Avatar
Nice block cleanup on the 5.3. Looks pretty nice.
How did the engine crane fail?
Old Apr 20, 2007 | 08:50 PM
jons03's Avatar
I'm tuned in. Lookin to do the same or 6.0 swap into my dad's 87.
Old Apr 20, 2007 | 09:15 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Ahh... I remember when my C10 went through heart surgery. Didn't take to time to repaint the block though. Very nice!
Not exactly what everything looks like now, but this was when I first did the conversion.
Old Apr 21, 2007 | 09:54 AM
Here is a list of special parts so far that i used, that directly relate to just the conversion.
all summit numbers
HUP-HP3795 ---- Hughes flexplate adapter from ls1 >> oldshool trans/converter(cheaper then the 6.0 spacer and longer bolts)
TRD-4592 ---- Engine mount Adapters ----- only used the 'plate' and the hardware
ATM-2268 ---- oil pressure adapter ----- metric to npt adapter for the auatometer sender
ATM-2277 ---- water temp adapter ---- it is metric to npt adpater for the passenger side head plug
trans issue --the stock crossmember for a TH350 in that truck is a bit off, the engine was moved forward about 1-1.5 inches, and the trans need to get raised about 3/4 inch for the correct angle. so i am just going to get a peice of 3/4 plate and drill the correct holes for the trans mount and crossmember. should work fine.
i might see if a 4 speed longbed truck driveshaft will work but i probably just get one made.
off topic --
ill tell you what .... just helped a friend of mine install a tr224 114 in his 01 ta, That was a pain in the a$$. new oil pump, timing chain, and all new valvetrain. this was the first cam swap i ever did in a car, let alone ls1, it took us two 10 hours from start to finish. but so worth it!
i dont think i am going to mess with sbc for a while depending on how this thing runs, might just convert everthing i own to genIII
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
atxlt
Jul 20, 2015 11:06 PM
