5.3 Cam Swap Question
Old 09-11-2013, 03:22 PM
skaffy03's Avatar
Default 5.3 Cam Swap Question
I'm about to do a cam swap on my 5.3
Can someone point me in the right direction for a new crank bolt and what gaskets I'll need to replace? And any other things like that.
I'm looking at a 212/218 but would rather find one used first. If anyone knows of one or has one, lemme know!
Old 09-11-2013, 03:27 PM
06murder's Avatar
You cane go to the dealer and get a new one or get a apr bolt.it be good time to get a underdrive pulpy while its a part.you will need timing cover gasket and water pump gaskets
Old 09-11-2013, 04:33 PM
skaffy03's Avatar
Is it arp or Apr?
Old 09-11-2013, 04:38 PM
CCrowell2's Avatar
Its Arp
Old 09-11-2013, 06:39 PM
skaffy03's Avatar
I'm new to doing cam swaps, but what's the real reason for needing a new crank bolt?
Old 09-11-2013, 10:17 PM
910506chevy's Avatar
one lowest prices ive found on ARP bolt
Arp 234 2503 Harmonic Balancer Damper Bolt Chevy LS1 LS2 LS3 L92 | eBay
I reused my timing cover gasket.. that is if you don't mess it up pulling it off .
Old 09-12-2013, 01:21 AM
skaffy03's Avatar
I've read the write up thread on ls1howto, but does anyone have any other good tips or suggestions that might make this all easier?
Old 09-12-2013, 01:50 AM
ChevyRad01's Avatar
Texas speed sells a basic cam swap bolt & gasket kit that I used when swapping my cam. Just make sure you've got all the tools you need and it "should" go smoothly.
Old 09-12-2013, 02:22 AM
skaffy03's Avatar
Thanks for all the help guys. Once I save a few more bucks ill have the cam bought. Can't wait to get this thing done.
Old 09-12-2013, 03:21 AM
silveradokidd_4518's Avatar
Bolt stretch...
Quick Reply: 5.3 Cam Swap Question
