5.3 Cam swap at 190K miles would you change oil pump & timing chain?
Old Mar 20, 2014 | 01:22 PM
maroon88iroc's Avatar
Default 5.3 Cam swap at 190K miles would you change oil pump & timing chain?
I just ordered my Cam kit for my 5.3 truck with 190K miles (214/222 559/566 w. 115 LSA... Looking to get some feedback on if you guys would change the timing chain/oil pump?
I did alot of research and alot of people said they did cam swaps at high miles and didnt change anything but the cam springs and PRods. I am going budget friendly on this mild build & still have LT's & Converter to buy so I'd rather use the money towards those items. Oil pressure is great and the truck runs fantastic so I am not worried about them lasting longer.
If this is one of those situations where the pump and chain are only like $100 for both Id like to get them but I havent seen anything real cheap. Steer me in the right direction. Would you swap the pump/chain? if so what pump & chain & where is the cheapest place to buy?
thanks,
-Gibson
Old Mar 20, 2014 | 02:35 PM
mdwatts11's Avatar
It's a small investment for insurance of your motor and piece of mind.
Old Mar 20, 2014 | 03:07 PM
whitedakota's Avatar
I didn't change mine with 16x,xxx miles now almost 180,xxx and I turn it 6800 rpm shift points daily! 2005 5.3 lm7
Old Mar 20, 2014 | 08:04 PM
batboy's Avatar
11 Second Club
I would consider 190k high miles. Yes, I would change things out for insurance purposes.
Old Mar 21, 2014 | 04:06 AM
Noah Burns's Avatar
at 190k miles... I'd go double roller gear, oil pump... new short block, lifters, etc...
Old Mar 21, 2014 | 04:52 AM
TIM Z's Avatar
11 sec. Truck Mod
When doing a cam swap always change / upgrade to an LS2 timing chain . I'd do the pump to .
Old Mar 21, 2014 | 11:01 AM
black00chev's Avatar
Slowest turbo build ever!
Timing chain for sure. Iwis makes a really good replacement chain. Oil pump should be ok, but it wouldn't hurt to put a new one in.
Old Mar 23, 2014 | 04:08 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Replace both while you're in there, no doubt.
Old Mar 23, 2014 | 09:38 PM
mjs1012's Avatar
I would do both while you're in there. I used a melliing m295 pump and ls2 chain I'm my ls1.
Old Mar 24, 2014 | 01:46 AM
gamble686's Avatar
Ls2 chain for sure oil pump is a good idea too but not necessary.
