5.3 build help!
Old 11-12-2015, 10:03 PM
2001silverado5.3's Avatar
Default 5.3 build help!
Okay guys I'm wanting to build my 5.3 I've already got all or most bolt ons, even have 4:10 gears in the rear and corvette servo in tranny. Was put running most things around the greenville SC area but now it's time to do internals and I personally do not know where to start, I've had thought on 6.0 stroker nitrous swapping it but I'm not sure I'd like to stick with my 5.3 and make around 550 whp when I'm finished. Any suggestions??
Old 11-12-2015, 10:39 PM
FFDP's Avatar
Slap a supercharger and there with nothing else and you'll come close to meeting your goal.
Bottem end never really needs to be touched for the power you want but a cam swap will help with power.
Then the transmission will likely explode.
Old 11-12-2015, 10:42 PM
That's the thing though I want to stay as N/A as possible
Old 11-12-2015, 10:51 PM
Vortec350ss's Avatar
Thats a lot of power for a 5.3. Do you consider nitrous to be as NA as possible?
AFR205's with a big cam, and a 87mm truck intake spinning to 6700 or so with a 150 shot would get you there.
Old 11-12-2015, 11:03 PM
It's either nitrous or just bite the bullet and go with an on3 turbo
Old 11-13-2015, 02:21 PM
zblee's Avatar
To get over even 400rwhp you will need nitrous/turbo/supercharger. you will most likely not get over 400rwhp without any of those.
Old 11-13-2015, 02:49 PM
ezdaar's Avatar
Used Blower, cam, Full Speed engineering exhaust.
4L80 swap.
Under $6K
Done.
Old 11-15-2015, 11:13 AM
Why stay NA by the time you are done you will have way over the cost of the blower with way less reliability especially if you are spraying it. But to each his own i've been down the same road in the past. But as stated that's a lofty goal for a 5.3. It's time for more displacement and you'll get there easily.
pewter00
11
10-20-2023 05:40 AM
carid
10-02-2015 09:33 AM
Dawas
09-20-2015 12:00 PM
racedad70
09-16-2015 01:51 PM
ClintBeastwood
11
09-13-2015 11:49 PM
Quick Reply: 5.3 build help!
