5.3,6.0 L engines, ballanced internal or external?
Old Nov 20, 2004 | 03:46 PM
busta9876's Avatar
Default 5.3,6.0 L engines, ballanced internal or external?
I've got a 6.0L that i bought and did not come with a flex plate, i've got a flex plate the will bolt up to it, but does not have a weight on it.
are the 6.0 and 5.3 internally ballanced?
thanks
Brendan Patten
Old Nov 20, 2004 | 05:15 PM
L-EATER's Avatar
11 Second Truck Club
Yes they are internal, the flexplates will interchange-just be sure to use the right one for the tranny you are using.
Old Nov 20, 2004 | 10:04 PM
gonzo 6.2's Avatar
I believe the 99-2K 6.0 flexplate is different,double check
Old Nov 21, 2004 | 02:32 PM
ktmrider's Avatar
This is correct! The 99-00 crankshaft is different where the flexplate ( flywheel ) mounts to it. I believe it is thicker by 0.200" and causes torque converter to tranny mounting problems. BigTex/Richard can shed more light if needed.
Bumpers
Aug 4, 2024 09:44 PM
Three6GMC
Nov 5, 2015 10:02 PM
steves86ta
Jul 28, 2015 10:21 AM
ullose272
11
Jul 17, 2015 07:22 AM
supersportsteve
Jul 4, 2015 12:02 PM
