5.3 to 6.0 harness the same?
Old 12-01-2016, 03:15 PM
Rrodriguez13's Avatar
Default 5.3 to 6.0 harness the same?
Hello i have a 2005 silverado with the 5.3 and i want to swap over to a 6.0 from a 04 escalade i wanted to know if i could use the 5.3 harness for the 6.0? Thanks in advance
Old 12-01-2016, 03:16 PM
arthursc2's Avatar
Received 1,434 Likes on 1,062 Posts
The DBW guys can chime, but I dont think you need an X link
All the rest of it is the same
Old 12-01-2016, 03:21 PM
Thanks! Can i use the 5.3 intake just to keep the DBW? I dont want to go through the trouble to change it over to DBC
Old 12-01-2016, 03:23 PM
arthursc2's Avatar
yes. Bolts right on
Old 12-01-2016, 03:33 PM
yes. Bolts right on
Thanks alot man!
Old 12-01-2016, 05:06 PM
madmann26's Avatar
Swap the motors already.
The only thing I would keep from the 5.3 and put it on the 6.0 is the throttle body and that's because of the TAC module.
Old 12-01-2016, 11:27 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Swaps right in the 05. Slap your 05 intake assembly on and everything else should plug right in
Old 12-02-2016, 09:57 AM
turboal1's Avatar
Default swap
I went from a 5.3 to a 6.2 in my 2010 and it
was a perfect PNP, used the 2011 Silverado
PCM OS file. downloaded from HPT file storage.
Old 12-02-2016, 07:35 PM
Thanks alot for the feed back guys i will be doing the swap as soon as i have some spare time!
Old 12-03-2016, 06:01 AM
Mark-welds's Avatar
Check the alternator plug. Mine turned out different between the caddy and sierra.
