4L60E shift kit, servos, etc. questions
I'm getting ready to do some trans work on my '02 silverado and I have some questions for you all.
1) What type of fluid do you all recommend? redline, rp, or mobil-1?
2) Is a B&M Cooler good, or should I use another brand?
3) Transgo or TCI, and which kit of the two?
4) I keep hearing about Billet Servos, what do you all think about them?
thanks.
thanks.
trans go, get a cooler with its own spall fan, and mobil 1 (runs 15-20 degrees cooler), i thnk the 4L60E's after 2001 have vette servos already....just what I've heard on the board.
My 03 didn't have vette size servos.
Go with the Transgo. All I could find for fluid was synthetic or Pennzoil ATF. Synthetic fluid isn't good so I hear. I did run an additive to it called DuraLube. It comes in a red bottle. It was HIGHLY recommended by the builder.
Does that Duralube (sounds so nasty!) come in like a 10oz bottle? If so, I've seen that before and wondered about it...
I recommend CHEAPASS DexIII/Mercon. I change mine every 10k mi. It's so inexpensive not to change it often. Syn fluids cause these to slip for some odd reason and they are like what $5/qt? Um no, I'll just keep changing mine often. This is common practice for my vehicles and when I do maintainence for my Pops, Moms, etc. and everything is working well.
B&M Cooler has proven to be superior to a tube + fin, go for it. It's cheap insurance you can't beat.
TransGo hands down has the better kit. I use nothing other than in any of my rides where applicable.
Billet servos can be harsh on a stock/low stall converter. The intermediate offers MUCH greater holding capacity than the 'Vette one. There are two of these... one for the 1-2 shift and one for the 3-4 (Intermediate and OD). I'm one of the few than has both billets (Chingon does as does Mudz5.3). If you're doing them use NO washers in the 1-2 accumulator on a stock or mild stall...even with a larger stall like Chingon has, just open the feed holes to...
1-2 .120
2-3 .099
3-4 .120
And that should negate any artificial firmening (is that even a word?! ) by those washers as they only help the 1-2 upshift which the billet intermediate does...
The 'Vette servo is a decent quick upgrade (I can get them for like $8) over the stock apply piston but it isn't HUGE gains over.
Finally get an aluminum 1-2 accumulator piston. Plastic stocker cracks, loses pressure, causes slippage on shifts, and then helps tranny die quicker.
1-2 .120
2-3 .099
3-4 .120
Yeah, go for the Transgo, billet servo's and cheap fluid. Do listen to HitmanX. No washer in the 1-2 accumulator. Read my post called (My interesting Trango/billet install. Rough day let me tell you.
Oh yeah! Billets are a BIG PITA to install, you're warned...
