454 LSX Build HP Estimate
Old Sep 26, 2007 | 06:28 PM
dirt track racer 81's Avatar
Originally Posted by adams2003
Yeah im expecting anywhere from 500 -550 to all four wheels on the local mustang dyno....probably closer to 500.
ive seen 377 14.5:1 comp roller huge heads dirt track motors make 522 at 8500rpm but yet a 468 big block 13:1 comp ration .650 roller cam proline heads make 350 rwhp..the guy was hopin for 750..thats the farthest ive seen a guy off when i used to work at the dyno shop in town
Old Sep 26, 2007 | 06:51 PM
if you dont mind PM me what you're lookin at cost wise for the build. I cant wait to see this thing up an running.
Old Sep 26, 2007 | 06:57 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
A smaller cam will help move his heavy pig and the high flowing heads will help it carry the power up top. This is EXACTLY what Im experiencing with my 420 and a 224 cam. My heads flow 335cfm at 600 but Im only running a 560 lift cam, it drives AWESOME down low but still screams up top for what it is and being choked by the stock intake. Just my .02 from driving basically the same setup just smaller cam/cubes.
Old Sep 26, 2007 | 06:58 PM
1slow01Z71's Avatar
About 8K is what you will be looking at for that setup.
Old Sep 26, 2007 | 07:06 PM
Quik's Avatar
5 year bitches!
with that low of compression i dont expect the full potential of that combo. might be a partial dog and only make low 500 to wheels
Old Sep 26, 2007 | 07:56 PM
adams2003's Avatar
Originally Posted by dirt_track_racer_81
i could be wrong here but to me if the ls7 heads flow an enormous amount of air why not get a cam that can benefit the big heads and flow that enormous amount of air..the stock cam of an ls7 is like around .59x lift...too me its like runing a 408 on a stoker on a ls1 hotcam..decent duration but low lift..its something you can also play with after you get it goin..there could be more left on the table..swappin a cam is only a 2-3 hour job if you dont have to change springs
Me and my engine builder both agreed that there was no point in going much past .600 lift with the cam because the ls7 heads drop off dramatically in flow after .600.
Old Sep 26, 2007 | 07:58 PM
adams2003's Avatar
Roughly 10K including:
-shortblock
-assembly of the motor
-ported ls7's
-harland sharp rebuilt ls7 rocker arms
-ported ls7 manifold
Old Sep 26, 2007 | 08:02 PM
adams2003's Avatar
LOL.....partial dog I highly dought. What you have to keep in mind is (said this in my first post) they way the pistons were designed compression loss is much much more minimal than your standard flat top or dome piston. Meaning although the cr is 10.85 it will act more like a much higher compression motor. My engine builder told me he would be highly dissapointed if it made anything less than 700hp at the flywheel (peaking around 6300rpms).
Old Sep 26, 2007 | 08:51 PM
Quik's Avatar
5 year bitches!
just going off what other 4xx cubed motors are doing. hope best for ya but only the dyno will tell
Old Sep 26, 2007 | 10:58 PM
93TAWicked1's Avatar
Damn How did you get it all done for 10k?????????????
I'm into mine about that and I used the top end off my all bore 388 motor. I am starting to think that a "budget LSX" might be in order for the Yukon...maybe a 427 with a L92 top end, I bet I could get into that for 8k or so....
