410 gears and 28"slicks ?
Old Mar 23, 2003 | 12:07 AM
GMC SKI's Avatar
Default 410 gears and 28"slicks ?
Well I just ordered a set of Et streets 28x11.5X16 tires
Now here is my dilema what gear should i go with now?
I've got 342's from the factory
I'll be replacing the g80 with a eaton posi in the next couple of weeks
I'm not sure what gear to go with 373's Or 410's
i don't wanna run out of gear in the 1/4.
I wanna finish in 3 third
Planning on shifting the truck at 5800 rpms maybe a little lower depending on how much boost I'm making with the smaller pulley
any Ideas on what i should do
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Jim
Old Mar 23, 2003 | 05:13 PM
creederado's Avatar
Default Re: 410 gears and 28"slicks ?
GMC SKI, are your et streets on back order, mine are? What rims did you end up getting?
I went with leftovers from ceterline direct.
16x9.5 5" backspace billet. wiegh around 20lbs. <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
Old Mar 23, 2003 | 05:59 PM
Grey Silver's Avatar
11 Second Club
I,ve got 4.10s with 28" slicks and there is plenty of room. At 103mph I'm around 5400 rpm. Found a formula that works and it goes like this
4.10 gear x 115 mph x 336 divided by 28" =5658 rpm. Add a few hundred rpm for the converter slipage and you end up with 5950 rpm at 115 mph in 3rd gear give or take a little.
If you can go this fast in the 1/4 you might need to change something and stay out of my neighborhood!
Old Mar 23, 2003 | 09:11 PM
FarmTruc's Avatar
Performance Trucks Sponsor
I went with the same thing, 28.11.5 on 15's though and an auburn unit with 4.10 gears. I was wondering how high the rpms would be at the end, thanks for the info.
havent' run it yet,
allen
Old Mar 24, 2003 | 12:18 AM
StupidFast's Avatar
I also have 28in. tires. I would go with the 4.10s, although I have never made a full 1/4 mile pass with my gears. My best 60ft is 1.779 on the juice, it was cold and this was spinning.
How long have you had the procharger on your truck? Do you like it? Hard install? I will purchase some 42 injectors for my pick'em up.
Oobray
Jun 13, 2022 03:38 AM
dragpac
Dec 8, 2015 05:48 AM
Gadgetized
Sep 9, 2015 10:46 PM
USMCvet0311
Aug 14, 2015 10:28 PM
elpyro89
Jul 28, 2015 05:51 PM
