408 stroker HELP
Old Jul 13, 2009 | 02:10 PM
sm4127's Avatar
Default 408 stroker HELP
hi guys building a 408 stroker. Im confused about compression. Using 243 heads and a weisco carrillo stroker kit. If im driving this on the street, They say i have to keep it down to 10.5 to 1. I dont understand why not 11 to 1. something about the octane. Thanks for any help
Old Jul 13, 2009 | 02:22 PM
krambo's Avatar
I'm running 11.5:1 on mine...took it to work (130 mile trip) on Friday. I run pump gas with no issues.
Old Jul 13, 2009 | 06:53 PM
budhayes3's Avatar
PT's Slowest Truck
I was talking to some engine builders last week, and the consensus was that the GM GenIII engines can squeak out a little more compression on the street. You have to look at the camshaft profile also, as a cam with more overlap will have a natural EGR effect and therefore have lower cylinder temps, and also allow for (and sometimes require) more compression.
Old Jul 13, 2009 | 09:39 PM
joeyc125's Avatar
11 Second Truck Club
Listened to your idle clip, sounds pretty nasty, what are you running for a cam?
Old Jul 13, 2009 | 10:41 PM
GMCtrk's Avatar
I was talking to some engine builders last week, and the consensus was that reverse flow engines (such as the GM GenIII) can squeak out a little more compression on the street. You have to look at the camshaft profile also, as a cam with more overlap will have a natural EGR effect and therefore have lower cylinder temps, and also allow for (and sometimes require) more compression.
since when was the genIII reverse flow? I thought that was a LT1 thing.
Old Jul 14, 2009 | 07:47 AM
krambo's Avatar
Originally Posted by joeyc125
listened to your idle clip, sounds pretty nasty, what are you running for a cam?
248/254 .615/.622 112
Old Jul 14, 2009 | 11:12 AM
budhayes3's Avatar
PT's Slowest Truck
It's not, I effed up...
Old Jul 15, 2009 | 08:27 AM
shandy294's Avatar
Why did they reverse the flow? Anything to do with the #7 cylinder problems?
Old Jul 15, 2009 | 04:27 PM
JDC's Avatar
JDC
Their not reverse flow. They dont have water flowing through the intakes anymore . If you hold the top hose youll feel that it gets hot from the engine end first same as before.
Old Jul 15, 2009 | 04:59 PM
budhayes3's Avatar
PT's Slowest Truck
I was given mis-information...just did some searching and found out that coolant goes through the block then up to the heads...it is a conventional cooling system. Sorry about that....gonna go modify my posts...
