408 is finally in - got a problem.
Old Aug 8, 2004 | 11:24 AM
  #21
GREGGO's Avatar
My truck has a ground strap on the driver head also. But hell, it's been off since the first engine replacement. You definantly have a voltage problem. Keep checking fuses. It seems like I had a similar problem and found one of the smaller fuses that was giving me the problem.
Old Aug 8, 2004 | 11:36 AM
  #22
mwalls54's Avatar
Need More N2O Mod
guessing it might be a loose ground mabey. just start grounding everything and that might find the problem
Old Aug 8, 2004 | 12:47 PM
  #23
Scream's Avatar
MOOBIES Moderator
The ground that I missed was the one on the driver's side. I want to say that it connected to the block, but I don't really remember.
Old Aug 10, 2004 | 09:36 AM
  #24
Got my grounding issues worked out yesterday and everything is running fine now. Now just need to work on the tuning.
Old Aug 10, 2004 | 01:01 PM
  #25
Sweet. Are you tuning it yourself or bringing it somewhere to have tuned? Either way, good luck.
Old Aug 10, 2004 | 04:52 PM
  #26
shandy294's Avatar
Originally Posted by Scream
Did you check the ground straps? Really sounds like a ground problem to me.
Definitely ditto on the ground problem...seen it on dim trailer lights and slow cranking when everything else was ok.
edit: well,leave it to me to post before reading all the others first.
Old Aug 10, 2004 | 07:16 PM
  #27
O3GMC's Avatar
12 Second Club
glad to hear its up and running
Old Sep 1, 2004 | 06:04 PM
  #28
hefdaddy007's Avatar
so what ground was it so we know incase it happens to one of us??
and how does it run i'm thinking of one for mine.
Old Sep 1, 2004 | 06:31 PM
  #29
There is a ground that goes from the negative terminal of the battery that goes to the block, one that goes from the head to the ground post on the firewall, and one that goes from the firewall to the hood. I left off the one going to the head.
Runs great, once tuning issues have been worked out - most. May be getting ready to go to a shaft mount rocker system.
Old Sep 1, 2004 | 06:36 PM
  #30
STOCK_SUCKS's Avatar
Sounds Like A Ground That Happened To Me On My Old Chevy I Had A Loose Ground And None Of The Gauges Worked Right. Mostly The Alternator It Showed Almost No Voltage.
