4 link w/airbags ??
Old Jul 1, 2002 | 05:25 PM
CurtD's Avatar
10 Second Truck Club
Default 4 link w/airbags ??
Does anyone have 4 link with airbags if so did it help your traction?I have a 2001 Chevy ext. cab 5.3 with a supercharger,headers,magnaflow exhaust,3500 stall conv.,transgo shiftkit,4:10 gears and eaton posi.My best time so far 13.6 at 101.67 that was before the conv and transgo.I need to find some traction. Thanks for any help.
Old Jul 1, 2002 | 05:43 PM
GMC SKI's Avatar
Default Re: 4 link w/airbags ??
What kind of supercharger are you running ?
I heard that cal tracs work well
I'll be buying a set real soon there made by calvert racing
tell us some more about your setup
jim
2002 GMC sierra scsb ATI Procharger true dual W/magnaflow x-pipe yank 3000 2"shackle boost and a/f guages
ASM headers,flex fans and LS1 edit on order
Old Jul 1, 2002 | 07:11 PM
CurtD's Avatar
I have a vortech supercharger,JBA headers,3"magnaflow( soon to be true duals)4:10 Richmond gears,eaton posi,tci 3500 conv,transgo shift kit. Boyd wheels 17x8 front 17x9.5 rear Goodyear255,60 front 275,60 rear.2" bell tech spindles & 4"kit in rear.Alpine head unit,hi phonics componets front&rear & 2 10"hi ph subs.Oh yeah,also steel cowl induction hood,street scene mirrors,roll n lock bed cover.
Old Jul 1, 2002 | 08:26 PM
CashDudeHomie's Avatar
You could probably fit a wider tire than that on the back to help a little. Do you have a pic of your truck?
Old Jul 2, 2002 | 12:48 AM
Ryan23silverado's Avatar
Air bags do not hook up at all. They are just too soft and don't allow for the tire to stay pushed to the ground. A four link is probably a better traction setup, but go with something like coilovers in the back. Or, just try some caltracs first. Caltracs have a pretty good rep. here for giving good traction.
Old Jul 2, 2002 | 02:53 PM
MAD_RACING's Avatar
I fabricated a custom air bag suspension for my 01 sierra and YES it gets better tracion.I Used a torsion bar setup w/ panhard bar . You have to adjust your psi to find the "sweet spot" <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Jul 2, 2002 | 03:45 PM
1999stepside's Avatar
I have a 4-link with bags and it does get rid of the wheel hop, but I am not sure it is the best drag racing setup.
Old Jul 2, 2002 | 07:09 PM
MAD_RACING's Avatar
You're correct it's probably not the best setup for drag racing. But I gaurantee if you want the appearance effects of bags with a 4-link setup in the rear alot of the traction problems will disolve. The adjustability is tremendous if done right. If your serious about racing have the installer weld in coil-over brackets in the rear. When at the track just bolt them in and deflate the bags.
01'SEIRRA REG CAB STEP SIDE HT W/DJM LOWER CONTROL ARMS,CUSTOM 3-LINK,CUSTOM C-NOTCH,BAGS,K&N FIPK2,POWER-AID,ALL FREE MODS,WIRES,NGKPLUGS,HPP3,T-STAT,FLOWMASTER,ESCLADE DASH&DOOR HANDLES,CUSTOM STAINLESS GRILL,LEATHER,CENTER CONSOLE,20X9.5 NICHE,F 255/35/20 R 275/35/20 BFG G-FORCE KDW,SHAVED TAILGATE HANDLE,SHAVED ROLL PAN, MORE TO COME. ALL WORK DONE AT MAD RACING
nabozny21
Oct 17, 2015 07:47 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
99bluefirebird
Sep 17, 2015 08:05 PM
