4" exhaust systems?
I know some deisal exhaust systems will work on gas trucks. Might be going to a L92 based 427 10- 10.5 compression plus boost so the need to open the exhaust up will be needed.
Looking for a straight through design that is the quietest possible.
The truck is a 05 serria denali crew cab
I can fabricate the exhaust if needed if there was a muffler only, but a close fit would be better.
Im running a 3" magnaflow exhaust now single out
I was using the Corsa 4" cat back for diesel's and loved it...This was on a SSS radix'd 370ci...Just buy the right cab configuration and you should be good. I bought a Flowmaster dual 3" to single 4" Y pipe and some mandrel 3" bends and did all v-band connections...worked out very well..
my friend had a single 4" on his procharged 370.. it worked really well no restriction really.
i have a mid-pipe from a d-max cat-back, 4" v-band, dynomax bullet, and dump if you are interested.
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
