4.8 & 5.3
Old Dec 22, 2009 | 03:44 PM
gs7793's Avatar
Question 4.8 & 5.3
what are the differences between a 5.3 and a 4.8? I was told it was just the pistons and the pushrods but i just wanted to make sure.
Old Dec 22, 2009 | 03:49 PM
charcoal03silvy's Avatar
I've heard just the pistons, I've heard just the crank, and I've heard the crank and pistons.
Old Dec 22, 2009 | 03:56 PM
GMCtrk's Avatar
crank, rods, and pistons I believe
Old Dec 22, 2009 | 04:30 PM
SweetS10V8's Avatar
what are you trying to accomplish?
Old Dec 22, 2009 | 04:38 PM
gs7793's Avatar
well i talked to a guy today who was tearing down a 5.3 and he was telling me all that was different was the pistons and the rods so i was thinking about getting some 5.3 pistons and rods to have a better starting place than the 4.8
Old Dec 22, 2009 | 05:04 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
The 4.8 has a shorter stroke than the 5.3, and uses flat-top pistons. The 5.3 uses dished pistons. If you put 5.3 pistons in a 4.8, you will be lowering the compression ratio, which will hurt performance instead of help it.
If you're looking to build your 4.8 into a 5.3, I believe you could swap in the crank & rods and be done. Use the 4.8(flat-top) pistons for a higher compression ratio. Pick out a cam that suits you and get it tuned.
Good luck with the build!
Old Dec 22, 2009 | 05:57 PM
batboy's Avatar
11 Second Club
Right, the 4.8 has a shorter stroke crank and uses different length rods. The pistons have the same pin height and same bore size, but the 4.8 is flat top and the 5.3 has a slight dish. If you are thinking of swapping parts between the 4.8 and 5.3, you should keep the crank and rods together. If you want to stroke a 4.8 to 5.3, then use a 5.3 crank and rods. I would keep the flat top 4.8 pistons unless you want less compression ratio (like if you want to run 87 octane gas or something like that).
Old Dec 23, 2009 | 12:08 AM
f4tal's Avatar
An there ya have it! lol
Old Dec 23, 2009 | 12:40 AM
viciousknid's Avatar
Where's the Beef?
Nothing else to say really.
Any more questions?
Old Dec 23, 2009 | 12:43 AM
Any more questions?
Can pigs fly?
