383 Project
Old Jul 31, 2008 | 10:38 PM
J.Garcia's Avatar
Cool 383 Project
I GOT THE BOTTOM END DONE ON MY 5.3 COVERTED INTO A 383 STROKER AND I GOT STAGE 3 5.3 HEADS FROM TEXAS SPEED........NOW WAT CAM SHOULD I GO WITH.....................SOMETHING MEAN AND THAT IT WILL WORK..................I FOUND A 232/232 DURATION AT A 600/600 LIFT WITH A 112 OR 110 LOBE...............AND WAT TYPE 0F INTAKE MANIFOLD SHOULD I GO WITH REMEBER ITS JUST A TRUCK TO **** AROUND WITH............NOT DAILY DRIVER:d evil::de vil:
Old Jul 31, 2008 | 10:57 PM
Stoichiometric's Avatar
A Fast90 intake manifold will work better for top end power than a truck intake. The 232 cam you posted will work best with a pretty loose converter, what do you plan to run?
Old Jul 31, 2008 | 11:06 PM
J.Garcia's Avatar
Real Low 13s All Motor.............but In Top Of All This I Want To Do A 2 Stage Nitorus Shot.................75 For Take Off And 100 The Second Shot....................i Also Have A Pi 3200 Stall With A Suted Up L60e Trany........................stock Gears Because I Broke My 4.11 W/ Amber Posi Track ...............with Nitrous I Expect Mid 12s
Old Jul 31, 2008 | 11:18 PM
quicksilverado's Avatar
I think you will do much better than low 13s N.A.
Old Jul 31, 2008 | 11:24 PM
J.Garcia's Avatar
Hopfully I Do And Thanks For The Support
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
