3 years of random misfire
Old Oct 2, 2016 | 10:14 AM
nnbs's Avatar
Originally Posted by Wolftrk99
key on engine off command pump on with a scan tool... Pressure should be between 345-690kpa (50-100psi) after pump is turned off it should stabilize between 500-599kpa(72-87psi) (if more than specified, replace fpcm, if less check for restricted fuel feed pipes or poor harness connections, if the test normal replace fuel pump)
Update
Swapped fuel tank with friends truck and still the same , other truck runs completely fine with 300 kpa pressure .
Both trucks have same pressure reading but mine have the misfire .
Old Oct 2, 2016 | 10:23 AM
Wolftrk99's Avatar
I would start checking the harness then.... Is your exhaust restricted?
Old Oct 2, 2016 | 10:26 AM
nnbs's Avatar
You mean engine harness ?
Exhaust is 3.5" with cut-outs and straight through muffler
Old Oct 2, 2016 | 11:03 AM
Wolftrk99's Avatar
Yes engine harness... Have you tried swapping coils yet? Assuming you dont have cats that would eliminate the exhaust being a problem
Old Oct 2, 2016 | 11:19 AM
nnbs's Avatar
All coils swapped
Old Oct 2, 2016 | 12:58 PM
injectordyne's Avatar
FormerVendor
Default Ecu
Have you swapped the ECU out? With the same part #?
Old Oct 2, 2016 | 01:45 PM
nnbs's Avatar
Yeah swapped and flashed
Old Oct 2, 2016 | 01:51 PM
FormerVendor
Default re: misfire
i'm afraid that you have an issue somewhere in your engine wiring harness. back in the day, a friend of mine was a Saturn mechanic and they had 5-10 cars parked at the big central repair shop that had wiring harness issues. GM usually just wound up buying them from the owners.
Wolftrk99's Avatar
Swapped engine, ecm, coils, wires, plugs, injectors, going to assume new intake gaskets when engine was replaced, no cats to be clogged, its starting to sound like a harness issue of some sort.... Could be a broken wire at the crank sensor, an issue with injector circuits or coild circuits or anything in between.... Have you by chance checked the map sensor and maf/baro sensor against what they are actually reading? Going to assume youve checked for vaccum leaks including the brake booster....
Old Oct 2, 2016 | 01:53 PM
Wolftrk99's Avatar
Hell everything youve done to it at this point a $2-300 harness and couple hours to swap it out arent going to hurt anything....
