3" Cutout Enough?
Old Jan 23, 2020 | 12:16 PM
  #21
dantheman1540's Avatar
I was looking at this vibrant merge since its actual stainless where the flow master is aluminized.
Old Jan 23, 2020 | 01:05 PM
  #22
00pooterSS's Avatar
Personally, don't like how it necks down, then expands back out. It's essentially a dual 3 into a single 3, that expands to a 4
Plus the 3" coming together isn't near as smooth
Defeats the whole purpose IMO
Old Jan 23, 2020 | 01:36 PM
  #23
I noticed that strange flare looking design. Before I order anything I'm gonna stop by a local import shop that just opened up and is only 15 minutes from me. They are the only shop within 20 miles and their instagram weld photos look top notch. Just spoke to the owner and he said come show him exactly what I want because he may be able to make make a merge out of stuff he has cheaper and nicer. I'm hoping he can get me V bands and stuff cheaper and possibly measure and order drive shafts for me.
Old Jan 23, 2020 | 02:56 PM
  #24
tjmath's Avatar
Originally Posted by 00pooterSS
He's going from dual 3" header collectors to a single 3" pipe that he has right now, to a dual 3" inlet Y pipe merge with 4" inch
So dual 3" to single 3" changing to dual 3" in single 4" out.
Dual 3" into single 3" is basically just running a single 3" and killing the point of having 3" collectors on the headers if you're gonna slam both of them into one 3" pipe. And even with 400 rwhp you'll see a gain going dual 3" or single 4" over single 3".
He's got a heads, cam, supercharged 6.0 if I recall correctly without going back and looking. That's gonna see a gain.
That's why I was saying that it would be the easier, and probably better performance wise, to do dual 3" cutouts. When the cutout is closed in the 4" system you open up and then immediately neck back down to 3". Dual 3" open cutouts should flow more than dual 3" pipe into a single 4" cutout.... no?
Old Jan 23, 2020 | 03:05 PM
  #25
Yes I agree dual 3" cutouts would flow more than a single 4" but I don't know If I have that space or want to complicate the setup that much. From my googling 4 should support my power level (600ish) and the difference between single 3" and single 4" is big where Single 4" to dual 3" Isn't that much difference.
Plus not sure why but I feel like single exit sounds rowdier at high rpm than dual. What do you guys think?
Old Jan 23, 2020 | 03:35 PM
  #26
tjmath's Avatar
But its not really a 4" exhaust.... its a 4" opening at the end of your 3" exhaust. IMO dual cutouts would be the way to go for what you want to do with trying to keep the sound level down with the cutout closed. Like has already been said, the power loss of a quiet muffler is minimal. But the differences between dual 3" vs a single 3" vs a single 4" I think that the dual 3" flows the most and will net the most gain over current.
Old Jan 23, 2020 | 03:36 PM
  #27
00pooterSS's Avatar
you are no doubt correct, two 3" inch is better than a single 4"
but where constraints come in a single 4 is FAR better than single 3" and not too bad of a compromise at his power level. Hell on a 500 whp vehicle I'd like to see at least a single 4. If you read up on pipe size vs hp calculators/charts, it's shocking to see what they recommend for minimums and you'll come away thinking none of us have large enough exhaust
I just assumed two cutouts would be complex and pretty expensive compared to one in a 4" merge. Plus the 4" merge will always be there and in use. Exhaust can actually neck down in size as it goes along in length and still flow well. But yes dual 3 flows more than single 4
But there's also length, venturi, velocity considerations. If you watch testing videos a lot of power is picked up from header extensions, in other words you want length of pipe pretty much as long as possible to take advantage of scavenging. If you place the 4" merge in there you're slightly reducing overall diameter but keeping a good size flow capability and lengthening the pipe then place the cutout well behind that then neck down to 3" and you've got a pretty nicely designed setup.
Singles always seem to scream more.
But from reading I've done on people that look into it's usually due to a y pipe setup vs a X or H pipe that gives a bit more rasp/scream/higher pitch. However, a better merge actually is supposed to help with some of the rasp. That came from people that have fooled with it. I have not personally done back to back testing.
Old Jan 26, 2020 | 10:08 PM
  #28
Spoke to my local fab shop and they are down to do the single 4" setup so parts have been ordered and hopefully in a week or 2 I can post pics and sound clips.
Old Jan 27, 2020 | 07:34 AM
  #29
03sierraslt's Avatar
just keep it all mandrel bent. FYI, I have the exact numbers on here somewhere but way back when I had a single 3” exhaust with the blower and my back pressure was 16psi with only 14psi boost or so. That’s horrible, even the exhaust sounded like a big air leak at wide open. I changed to a dual 3” from my collectors to single 4” with a cutout and it had no measurable back pressure with the cutout closed on the same setup.
I still have the same exhaust setup with the turbo only now it’s a 4” DP into the 4”. I haven’t measured exhaust back pressure yet but my turbine back presssure is only 1.75-1 at 17.5psi so my exhaust back pressure can’t be to high. Once weather breaks I’ll test with and without the cutout open to compare.
Old Jan 27, 2020 | 07:51 AM
  #30
That's awesome to hear. I've seen several big HP guys on here run 4" with no complaints so I'm excited.
